Not able to flash MPC5775B using S32design studio
1,086件の閲覧回数
Gad_usr1
We are using the MPC5775B-EVB. We are not able to flash the controller using S32 design Studio. Earlier this was working, but suddenly it has started hanging. Please see below screenshot.
2 返答(返信)
1,043件の閲覧回数
lukaszadrapa
Hi @Gad_usr1
according to your screenshot, it looks like the project is loaded but there's some problem in startup files and main function cannot be reached.
Try to uncheck "Run on reset" in Debug Configuration:
Then the program should stop right at the entry point after loading. Is this working?
If yes, try to step the startup files to see where it crashes exactly.
Lukas
1,037件の閲覧回数
Gad_usr1
Since it was hanging, we were not able to put breakpoint. It is hanging in verifying CRC. We tried to download the code once to RAM, then it worked. After this we were able to download to flash again.
