Measuring clock cycles with MPC5744P
1,371 次查看
kshitij_dadheka
I have a function and I need to measure the near exact number of processor cycles it takes to execute. I am able to measure the time in microseconds with a PIT timer on the MPC5744P, but I was not able to find a high-level function/utility in the SDK PA RTM 3.0.0 which can measure the processor cycles. More importantly, I would like to see how various compiler optimizations settings affect the processor cycles taken for executing. Any help would be really appreciated!
Kshitij Dadhekar
1 回复
1,293 次查看
petervlna
Hmm, most accurate will be tracing via some debug tool.
From SW point it can be any timer.
Or a Pin toggle before and after executed code and measurement with scope.
There is no internal core timer like on z7 cores for this purposes.
regards,
Peter
