MPC5777C - Performance Monitors outside the core
MatheusFranklin
Hello!
I know that the e200z7 core has a PMU (Performance Monitoring Unit) which can count hardware events. However, I would like to know if the MPC5777C has more performance monitors outside the core that can count events like misses in the PFLASH mini-cache, for example.
Matheus.
davidtosenovjan
So every monitor that can count hardware events are listed in the Performance Monitor chapter of the e200z7 core RM?
- Basically yes, you are right.
Does not the peripherals have performance monitors themselves?
- No, they don't have.
Does not the Nexus debug module have performance monitoring features?
- Nexus may have TRACE feature, offering lot of capabilities that are however rather feature of the tools itself. You may see for instance following:
https://www.nxp.com/docs/en/application-note/AN4591.pdf
davidtosenovjan
I have been dealing with Performance monitor in the following thread, pay attention to links at the bottom:
https://community.nxp.com/t5/MPC5xxx/cant-write-in-MPC5744P-performance-monitor-registers/td-p/14962...
However performance monitor is a feature of e200 core. The most external event are BIU (bus interface unit) related.
MatheusFranklin
Thank you for the reply, David!
Matheus
davidtosenovjan
%3CLINGO-SUB%20id%3D%22lingo-sub-2007367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPC5777C%20-%20Performance%20Monitors%20outside%20the%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2007367%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello!%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EI%20know%20that%20the%20e200z7%20core%20has%20a%20PMU%20(Performance%20Monitoring%20Unit)%20which%20can%20count%20hardware%20events.%20However%2C%20I%20would%20like%20to%20know%20if%20the%20MPC5777C%20has%20more%20performance%20monitors%20outside%20the%20core%20that%20can%20count%20events%20like%20misses%20in%20the%20PFLASH%20mini-cache%2C%20for%20example.%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EBest%20regards%2C%3C%2FP%3E%3CP%3EMatheus.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2010168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC5777C%20-%20Performance%20Monitors%20outside%20the%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2010168%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESo%20every%20monitor%20that%20can%20count%20hardware%20events%20are%20listed%20in%20the%20Performance%20Monitor%20chapter%20of%20the%20e200z7%20core%20RM%3F%3CBR%20%2F%3E-%20Basically%20yes%2C%20you%20are%20right.%3CBR%20%2F%3EDoes%20not%20the%20peripherals%20have%20performance%20monitors%20themselves%3F%3CBR%20%2F%3E-%20No%2C%20they%20don't%20have.%3CBR%20%2F%3EDoes%20not%20the%20Nexus%20debug%20module%20have%20performance%20monitoring%20features%3F%3CBR%20%2F%3E-%20Nexus%20may%20have%20TRACE%20feature%2C%20offering%20lot%20of%20capabilities%20that%20are%20however%20rather%20feature%20of%20the%20tools%20itself.%20You%20may%20see%20for%20instance%20following%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4591.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN4591.pdf%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2008440%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC5777C%20-%20Performance%20Monitors%20outside%20the%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2008440%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EThank%20you%20for%20the%20reply%2C%20David!%3CBR%20%2F%3E%3CBR%20%2F%3ESo%20every%20monitor%20that%20can%20count%20hardware%20events%20are%20listed%20in%20the%20Performance%20Monitor%20chapter%20of%20the%20e200z7%20core%20RM%3F%3CBR%20%2F%3EDoes%20not%20the%20peripherals%20have%20performance%20monitors%20themselves%3F%3CBR%20%2F%3EDoes%20not%20the%20Nexus%20debug%20module%20have%20performance%20monitoring%20features%3F%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20regards%2C%3CBR%20%2F%3EMatheus%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2008430%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MPC5777C%20-%20Performance%20Monitors%20outside%20the%20core%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2008430%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20have%20been%20dealing%20with%20Performance%20monitor%20in%20the%20following%20thread%2C%20pay%20attention%20to%20links%20at%20the%20bottom%3A%20%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMPC5xxx%2Fcant-write-in-MPC5744P-performance-monitor-registers%2Ftd-p%2F1496274%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FMPC5xxx%2Fcant-write-in-MPC5744P-performance-monitor-registers%2Ftd-p%2F1496274%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EHowever%20performance%20monitor%20is%20a%20feature%20of%20e200%20core.%20The%20most%20external%20event%20are%20BIU%20(bus%20interface%20unit)%20related.%3C%2FP%3E%3C%2FLINGO-BODY%3E
