The quick start guide is the document which is published as and there is nothing more as the web guide is just copied quick start guide. I believe we have supplied this with kit in past. Now it is online.
https://www.nxp.com/document/guide/get-started-with-the-mpc5775e-evb:GS-MCSPTR2A5775E
Which option shall I supposed to configure? all default?
Board is in default setup when is shipped and it can be directly used. User only has to configure JTAG header.
If you dont want SBC chip to reset your device imediately when you connect debugger, you have to remove jumper which connects reset from SBC to the microcontroller.
Otherwise everything should run just fine.
Peter
