Hi, I'm using SWT module now. My code can't realize the reset function. This is my code. I don't know what's wrong with my code. Can you give me some guidance?
This is my clock configuration
This is my watchdog initialization configuration
In addition, Does the reset module need to be configured manually? Or does SWT timeout automatically trigger the route to reset?Can you give me some guidance? thank you.
