MPC5748G-FREERTOS_code migrate
1,790件の閲覧回数
kalai
   i migrate the code one controller (s32k148 ) to another controller MPc5748G ,i get the output from transmitter section but i cant receive the data i dont know what is issue.so please refer  the code and suggest me the solution
i will attach the code below .
2 返答(返信)
1,773件の閲覧回数
petervlna
Hmm, its hard to say.
I can only guess, did you initialized peripherals properly (like SIUL unit for pins assignment) ?
Peter
1,763件の閲覧回数
kalai
HI
  i tried  with this code using uart data, i am not using any external hardware now(like gsm) , i send the data through hyperterminal uart  here transmitter  working but i can,t get the output when i receive data from hyperterminal .
uart is working both tx/rx alone .
thanks
kalai
