MPC5748G EVB error
MPC5748G EVB error
huqiang
Hi, My EVB seems have some error. And the LED D1 keep lighting.
I had tried the reset switch many times and there is no help .
How can I bring it back to normal?
Thanks!
lukaszadrapa
huqiang
      Thank you for your attention!
       I had tried your solution . But I still can not solve this problem.
     My problem seems different from the links that you give.
     I use the S32 DS as the debug environment and the "multilink universal " as tools.
     Besides, I can not find how to add the Slowreset option :
     System.reset
     SYStem.Option.SLOWRESET ON
     SYStem.CPU MPC5748G
     SYStem.BdmClock 4MHZ
     SYStem.up
Thank you!
Qiang
martin_kovar
look at this thread a try. If it does not help, please write me back.
How to debug multicore with S32 Design studio
Martin
huqiang
Hi Martin,
       The link really helps  me solve this problem.
       Thank you very much !
Qiang
