MPC5748G Bootloader
MPC5748G Bootloader
陈秀侠
         Recently I am using MPC5748G Bootloader.  In the community there is a AN Serial Bootloader for MPC5748G SW, but it seems to use greenhills ide,  I need to use s32ds to develop the  Serial Bootloader for MPC5748G.  I have try to modify the demo from greenhills to s32ds, but it doesn't work : the problem is  that  it can not jump from bootloader to app,  and reset or power up again it seems not work between  boot or app project.
        I use the DEVKIT-MPC5748G board. Here are my project.  Could someone help me check any problems in my project?
roxy2131
Hi. I'm having same problem too. Could your share the solution?
[email protected]
bhavesh
Hi Steven,
I am facing the same problem can you please share the solution.
Bhavesh Rathod.
陈秀侠
      I  have solved the problem.
