MPC5746R support transmitting SPI Signals Over LVDS Interface?
1,887 次查看
fedotech
Hello!
When I config DSPI_M0's pin_mux in S32DS for mpc5746r,  I found LVDS pair ports. Does MPC5746R support transmitting SPI Signals Over LVDS Interface?
I just need the ordinary DSPI. I can't find more information in Reference Manual.
By the way, please help me to check the following configuration, especially for SPI clock output pin, as there are two SPI clock output pins with LVDS.
Thanks!
1 回复
1,869 次查看
davidtosenovjan
HI, there is a such option there as you can see on the screenshot:
