MPC5746R Bootloader
MPC5746R Bootloader
2,428 次查看
qiaodeng
    We want to develop bootloader based on CAN for MPC5746R. Is there any example code or document for reference?
Thanks in advance.
Qiao
标记 (2)
2 回复数
2,108 次查看
宝程凡
Have you found or code the bootloader base can?Could you give me your solution?Thank you very much!
2,108 次查看
lukaszadrapa
Hi Qiao,
take a look at this application note:
http://www.nxp.com/assets/documents/data/en/application-notes/AN5319.pdf
http://www.nxp.com/assets/documents/data/en/application-notes-software/AN5319SW.zip
It's for MPC5748G but the principle is the same also for MPC5746R.
Lukas
