MPC5744P - start up
MPC5744P - start up
naveen_lingampe
i am new to MPC and i am trying to understand start up sequence of MPC5744P base on  a available project.
Below is the snapshot of mot file generated.
.boot_rcw is assigned to address 0x00FA0000 in linker script.
Below is the snap from startup code.
As per below info, _start is assigned value at address 0x00FA0004 which is 0x00FA0500
RCHW_VAL( .boot_rcw) is assigned value 015A0000 in start up file, which can be seen in mot file(at 0x00FA0000).
Not able to understand how the next 4 bytes in mot file(0x00FA0004) has value 0x00FA0500
Dont find any assignment anywhere in start up or linker.
Thank you.@@@
Tags (2)
petervlna
Just look at the value of _start.
Here you can see that first 4 bytes are RCHW word
next one is long. so 4 bytes with _start -> your start address value.
I am quite confused what are you looking for, could you be more specific?
regards,
Peter
naveen_lingampe
Hi Peter,
Thank you.
I am trying to know how the value 00FA0500 got generated in the mot file.
How the 4 bytes(Application start address) after RCHW word are assigned.
Thank you.
Naveen
