MPC5744P CAN Calibration Protocol Problem
1,355 次查看
nathan_
I want to use the CAN calibration protocol(CCP) function of MPC5744P.
My problem is if CCP version 2.1 is suitable for MPC5744P?
Best regards.
1 回复
1,172 次查看
petervlna
I see no issue in using CCP for MPC5744P as CCP is standardized measurement and calibration protocol used to calibrate ECUs independent of the manufacturer.
But as CCP is product of Vector I recommend you to first consult with them.
Peter
