MPC5675K customer programmable OTP flash
BG
does customer programmable OTP flash exist for the MPC5675K that can be used to save persistent information like part numbers?
There are "User Reserved" sectors within the test memory block (p.207 of the reference manual), but they are located within NVM flash that is marked as not programmable by the user.
Bernd
davidtosenovjan
There are 3 test flash areas:
Statement on page 207 only speaks about first test sector. Second two should be applicable for user's use.
davidtosenovjan
