MPC5674F DMA-SPI example code
EmbUser
hi,
I am using MPC5674F controller, would like to know if there is a example code available from SPI to transfer data from DMA.
thanks,
Nagesh
lukaszadrapa
EmbUser
Thank you for the code ,
I am not able to import this project into CodeWarrior
Installed Products:
- CodeWarrior for MCU
Version: 10.7
Build Id:160721
Can you please let me know where or how i can import the this into codewarrior,
lukaszadrapa
The example is created in Classic CodeWarrior 2.10. The easiest option is to create a new project in your CW10.7 and then just copy the code in main.c. Nothing else is needed.
Lukas
