MPC5644A GPIO Pin Connections
1,034 次查看
tgc-yilmaz
I am using mpc5644a. I'm driving discrete signals from GPIO 87 and 88.
However, which pins can I observe the outputs of these signals on the EVB? Can you help with this?
Thank you for your help...
1 回复
1,026 次查看
PetrS
refer to pin mapping of the EVB user guide for signal location on EVB pin headers.
Using Table 1. MPC5644A signal properties within device Reference Manual you will know GPIO/peripheral function/signal correspondence
Thus GPIO87/88 will be on PJ1 connectors
BR, Petr
