MPC5643l External Reset
1,579 次查看
manuelaielo
I'm trying to reset the micro via external reset, i.e. moving to low the RESET_B pin.
In the RM the external reset is classified as non destructive reset (in the same way as SW functional reset) so I expected that the RAM content will be preserved after external reset.
Instead I observed that the SRAM is no more initialized after an external reset and needs a complete initialization to avoid ECC errors.
I'm using a MPC5643l cut 3.1.
What is the expected behavior after external reset regarding data in RAM?
Thank you in advance
Manuela
标签 (1)
1 回复
1,457 次查看
davidtosenovjan
In case external reset SRAM content is damaged by memory BIST and must be re-initialized as well.
