MPC562 External flash programming
ソリューションへジャンプ
2,259件の閲覧回数
tbonkers
Hello
I am having trouble erasing an programming the external flash ( M58BW016DT) connected to a board with MPC562. I am able to read the flash, and read/write the internal registers of the MPC, however when it comes to write operations on the flash, I'm stuck. Can you please provide code/algorithm examples?
2,241件の閲覧回数
lukaszadrapa
flash programmer included in CodeWarrior 8.7 support external memories.
If there's no algorithm for your memory, you can follow this document to add it:
https://www.nxp.com/docs/en/white-paper/CWFLASHPROWP.pdf
Lukas
2,242件の閲覧回数
lukaszadrapa
Lukas
