MPC5607B Example Codes
IvelinIvanov
Hello everyone! Are there example codes that test the functionality of each sub-module of the above mentioned MCU? And if yes where can I find them ? Thank you in advance.
Kind regards,
                     Ivelin
petervlna
No there is not such sample code.
The example codes available are posted here:
https://community.nxp.com/t5/MPC5xxx-Knowledge-Base/MPC5-software-example-list/ta-p/1102445
and this could also help:
https://www.nxp.com/docs/en/application-note/AN2865.pdf
Peter
