MPC5604S Interrupt
MPC5604S Interrupt
1,209件の閲覧回数
akhilprasad
I am using MPC5604S controller. I have enabled some interrupts like ADC,watchdog,PIT etc.
How can I disable all the interrupts without disabling watchdog interrupt ? Watchdog interrupt should not get disabled when i disable the interrupts. Then after doing some specific task i need to re-enable all the interrupts. Can anyone share me a sample code ASAP.
1,079件の閲覧回数
davidtosenovjan
Hi, it is needed to setup watchdog interrupt for higher priority then others and set CPR in order to mask only those interrupt resources you need to have disabled.
