MPC5604EKIT Software
1,859件の閲覧回数
suhass
I have purchased an MPC5604E development kit, it's mentioned in the document that the image of the software is preloaded, Once if I dump my own code on the kit the preloaded code gets erased, hence I need source code/hex file/binaries for the same. So please provide the source files.
Thanks and Regards,
Suhas S
1,476件の閲覧回数
petervlna
If you didn't already erased the board you can just simple dump the flash content into s3 record or any other format via debugger.
Peter
