MPC5604E MJPEG buffer to SPI
1,469 次查看
suhass
I'm transferring MJPEG encoded data from circular buffer through SPI, but it is getting halted after few bytes of data transfer, Is it something to do with Errata Number e5865. Do address the Issue.
Thanks & Regards
SUHAS S
标签 (1)
标记 (1)
1 回复
1,384 次查看
lukaszadrapa
yes, it could be caused by the e5865. How did you set VE_MODE[AUTOCLR_GO]? If it is set to '1', it is not recoverable.
Lukas
