MPC5604B SPI no response
2,402 次查看
jeffcharles
MPC5604B is used as master and TLE9262(the peripheral chip) is used as slave in SPI. When I send some commands by SOUT_1, the TLE9262 is always no response. Is there anything wrong with my configuration? Please help me check the the code in the attachment.
The wave parameters:
CH A (Blue)      =>   CS0_1
CH B (Red)      =>   SCK_1
CH C (Green)   =>   SOUT_1
CH D (Yellow)   =>   SIN_1
Thanks.
标签 (1)
标记 (1)
1 回复
2,206 次查看
PetrS
the setting looks normal and the generated signals are as expected/programmed.
Check TLE9262 connection, circuitry and functionality.
BR, Petr
