MPC5554 BAM Bootloader via DSCI
1,730 次查看
tobayram
Im trying to write a bootloader for MPC5554 via DSCI. Im using winIdea for IDE and I have ic5500 debuger. Could you share me an example about this topic. Thank you.
标记 (1)
2 回复数
1,715 次查看
tobayram
Thank you Lukas, Im trying to code.
1,718 次查看
lukaszadrapa
Hi @tobayram
you can take a look at attached draft of application note "How to write flash resident
bootloader for MPC55xx/56xx" including sample code.
Here's published version for MPC57xx devices which provides more details:
https://www.nxp.com/docs/en/application-note/AN5319.pdf
https://www.nxp.com/docs/en/application-note-software/AN5319SW.zip
Lukas
