MCP5748G AVAS System Design
black_light
I am a newbie on NXP boards. I should be designing an AVAS system as mentioned on subject. I put a file that describes AVAS. Basically if your EV travels with less than 20 kmh, then a combustion engine sound is generated, this is what AVAS does. I have an amplifier, FDA903D, and a speaker with MCP 5748G. I am unable to proceed because learning the NXP is challenging. I should send data through dspi or i2c. How should I proceed, how can I make things easier? Indeed, this is an easy task, but when you are familiar with the board you use.
Thanks.
lukaszadrapa
Hi @black_light
Each board has user manual in pdf or Getting Started html document.
For example, if you have this board:
https://www.nxp.com/design/design-center/development-boards-and-designs/automotive-development-platf...
... you can find on the page:
https://www.nxp.com/document/guide/getting-started-with-the-devkit-mpc5748g:NGS-DEVKIT-MPC5748G
Then there's a nice training describing how to install S32DS and SDK and basic steps:
https://www.nxp.com/design/training/sdk-for-the-gateway-mpc574xb-c-g-mcu-family:VIDEO-MPC574xBCG-MCU
SDK then contains set of examples which you can use for first tests and learning.
Lukas
black_light
Thanks a lot. I hope these will be helpful.
BlackLight
lukaszadrapa
Hi @black_light
Lukas
%3CLINGO-SUB%20id%3D%22lingo-sub-1906765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCP5748G%20AVAS%20System%20Design%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1906765%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3EI%20am%20a%20newbie%20on%20NXP%20boards.%20I%20should%20be%20designing%20an%20AVAS%20system%20as%20mentioned%20on%20subject.%20I%20put%20a%20file%20that%20describes%20AVAS.%20Basically%20if%20your%20EV%20travels%20with%20less%20than%2020%20kmh%2C%20then%20a%20combustion%20engine%20sound%20is%20generated%2C%20this%20is%20what%20AVAS%20does.%20I%20have%20an%20amplifier%2C%20FDA903D%2C%20and%20a%20speaker%20with%20MCP%205748G.%20I%20am%20unable%20to%20proceed%20because%20learning%20the%20NXP%20is%20challenging.%20I%20should%20send%20data%20through%20dspi%20or%20i2c.%20How%20should%20I%20proceed%2C%20how%20can%20I%20make%20things%20easier%3F%20Indeed%2C%20this%20is%20an%20easy%20task%2C%20but%20when%20you%20are%20familiar%20with%20the%20board%20you%20use.%26nbsp%3B%3CBR%20%2F%3EThanks.%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1912017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MCP5748G%20AVAS%20System%20Design%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1912017%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20a%20lot.%20I%20hope%20these%20will%20be%20helpful.%3CBR%20%2F%3EBR%3CBR%20%2F%3EBlackLight%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1909699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MCP5748G%20AVAS%20System%20Design%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1909699%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F236744%22%20target%3D%22_blank%22%3E%40black_light%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EEach%20board%20has%20user%20manual%20in%20pdf%20or%20Getting%20Started%20html%20document.%20%3CBR%20%2F%3EFor%20example%2C%20if%20you%20have%20this%20board%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2Fautomotive-development-platforms%2Fmpc57xx-mcu-platforms%2Fmpc5748g-secure-gateway-development-board%3ADEVKIT-MPC5748G%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fdevelopment-boards-and-designs%2Fautomotive-development-platforms%2Fmpc57xx-mcu-platforms%2Fmpc5748g-secure-gateway-development-board%3ADEVKIT-MPC5748G%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E...%20you%20can%20find%20on%20the%20page%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-the-devkit-mpc5748g%3ANGS-DEVKIT-MPC5748G%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocument%2Fguide%2Fgetting-started-with-the-devkit-mpc5748g%3ANGS-DEVKIT-MPC5748G%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EThen%20there's%20a%20nice%20training%20describing%20how%20to%20install%20S32DS%20and%20SDK%20and%20basic%20steps%3A%3CBR%20%2F%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Ftraining%2Fsdk-for-the-gateway-mpc574xb-c-g-mcu-family%3AVIDEO-MPC574xBCG-MCU%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Ftraining%2Fsdk-for-the-gateway-mpc574xb-c-g-mcu-family%3AVIDEO-MPC574xBCG-MCU%3C%2FA%3E%3C%2FP%3E%0A%3CP%3ESDK%20then%20contains%20set%20of%20examples%20which%20you%20can%20use%20for%20first%20tests%20and%20learning.%3C%2FP%3E%0A%3CP%3ERegards%2C%3CBR%20%2F%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E
