LWIP example causes DevAssert
MattJCole
Contributor V
Processor 5748G
FreeRTOS V10.0.1
Component S32_SDK_C55
SDK S32_SDK_S32PA_RTM_3.0.0
I am using the DEVKIT-MPC5748G
The example application for the LWIP causes a DevAssert when you run it for a few minutes. Is there a reason this is happening and how can I stop it from happening.
MattJCole
Contributor V
I think I found out what the problem is. The default stack size in the demo is 512. I turned on "check for stack overflow" and a stack overflow happened. I increased the stack size to 1024. It has been running for 15 hours with no trouble.
MattJCole
Contributor V
