LINflexd transmission issue
pramodkashyap
Iam using Mpc5746c controller in my project,
Iam testing basic transmission of data using S32 ide example project for LIN communication, and transmitting hello space space space, iam seeing pulses only once on oscilloscope ,  the whole transmit function  is in while(1) loop, also checking that data transmission flag
(DTF) is not setting after transmitting data instead bit error flag(BEF)  is set,  please give some inputs on this issue ASAP.
Pramod
minghaodai
I'm having the same issue, did you find a solution yet?
