Is there some .brd for document proyect DRM166?
3,057 次查看
robertomojica
Im looking for the right controller for a automotive HVAC controller, i found Document DRM166 that have some good starting point. IS there any board (.brd)  for this concept design that i can test?
2,995 次查看
petervlna
I have sent you the project files separately to email.
Peter
4 回复数
2,995 次查看
robertomojica
Peter, thank you so much for the info, exactly what im looking for. you make my day when i wake up this morning and i find your replay.
I have just one question are this a good processor for the following years, or you suggest me to migrate to a newer design processor?
Thanks for your support.
Rob
2,995 次查看
petervlna
This really depends on your application requirements.
You can for sure use MPC57xx which are 55nm devices with more advanced safety and communication possibilities.
Or you can go with 16-bit micros as well.
Peter
2,995 次查看
petervlna
There is no orderable board for DRM166.
But are you referring to board physically or to schematics?
Peter
2,996 次查看
petervlna
Peter
