Initialize eTPU on MPC5777C stop at fs_memset32() function
wujt
I tried to initialize the eTPU on MPC 5777C, but the code stopped at fs_memset32() function. and I found the variable value@entry in the function was missing, and it stopped at "*p++ = value;", reporting align 4 IVOR1_Vector: e_b   IVOR1_Handler.  what is wrong with my initialization.
Thanks !
davidtosenovjan
Hi, could you describe what example is your code based on or how you achieve this result?
