How to use MC33908 fault detection function?
999 次查看
ziqianli
   I am using the SBC(MC33908) and MPC5744 in ECU design.Now I want to diagnostic the SBC fault,for example the SBC-CAN moudle fault detection,in datasheet it say when CANL or CANH short to power and gnd it will report the fault to the Diag CAN1 register.But when I create the fault,I found the  Diag CAN1 register related fault bit is not set! Can you help me to analyze the reasons?Thanks!
标签 (1)
0 回复数
