How to reset core0 alone using SWT0 in MPC5746R
1,240 次查看
renjithr
I want to reset core0 alone of MPC5746R using SWT0 without FCCU module. If possible please share the procedure or sample code
Renjith
标记 (2)
1,105 次查看
petervlna
I have made tests and what you want to achieve is not possible.
You can reset core1 via mode transition with ME_CADDR1.RMC = 1.
However if you reset the core0 your whole micro is reset.
On the other hand what you are trying to achieve makes no sense.
Peter
