mcu type: MPC5746C
how to receive the multicast mac address of ethernet, for example: the multicast address is 0x01-00-5E-xx-xx-xx
I use S32 SDK to config my project.
attachment is ethernet code.
thank you verymuch.
you should add address to group hash table, within SDK ENET_DRV_SetMulticastForward function can be used to update ENETn_GAUR/GALR registers.
For your adressess most probably all bits in GAUR/GALR will be set.
BR, Petr
