HSM: How to configure
1,099 次查看
sk4
I want to use HSM for MPC5748G device. Initially, I want to use it for Random no generation and later want to extend the use for signature verification.
I have earlier worked on RH850 where I have used TriCore s/w to access the HSM module for RH850. In this context, how HSM for MPC5768G works? Is there any configuration s/w available for it?
Any sample application to start with will be helpful. Thanks in advance.
948 次查看
petervlna
I have no information on RH850 HSM device.
However I can help with MPC5748G.
First you have to obtain security reference manual. There you can find described how HSM works.
I don't think so. There are some example SW in SDK for S32DS.
Furthermore without security documentation you wont be able to start HSM as it is by default disabled.
regards,
Peter
