FreeRTOS replacement for _klog_get_task_stack_usage and _klog_get_interrupt_stack_usage
1,224件の閲覧回数
MattJCole
Contributor V
I am currently migrating from the Kinetis K65 to the MPC5748G processor and need a replacement for the _klog_get_task_stack_usage(  _mem_size_ptr stack_size_ptr,   _mem_size_ptr stack_used_ptr) and _klog_get_interrupt_stack_usage(  _mem_size_ptr stack_size_ptr,   _mem_size_ptr stack_used_ptr)  functions. I found the uxTaskGetStackHighWaterMark function but that only gives me how much memory the stack used. How do I find out stack size for a task?
タグ(1)
1,214件の閲覧回数
lukaszadrapa
Hi Matt,
take a look at:
https://www.freertos.org/FAQMem.html#StackSize
Lukas
