Flexray cycle filter
Lyn
I am using mpc5748 board to develop flexray function. But I found at the slot that not assigned to any frames,null frame will transmit. I checked the configuration of MB and poc,cycle filter is enabled and right. I want to exhibit the null frame send. If someone knows about this,please help
petervlna
Answer is in reference manual:
46.8.6.2.6 Null Frame Transmission
A static slot with slot number S is assigned to the CC for channel A, if at least one
transmit message buffer is configured with the FR_MBFIDRn[FID] set to S and
FR_MBCCFRn[CHA] set to 1. A Null Frame is transmitted in the static slot S on channel
A, if this slot is assigned to the CC for channel A, and all transmit message buffers with
FR_MBFIDRn[FID] = s and FR_MBCCFRn[CHA] = 1 are either not committed, i.e
FR_MBCCSRn[CMT] = 0, or locked by the application, i.e. FR_MBCCSRn[LCKS] = 1,
or the cycle counter filter is enabled and does not match.
If the slot is in static case and it has assigned at least 1 message buffer but MB is not ready to transmit or it wont pass cycle filter then NULL frame is sent.
Peter
Lyn
Thank you for your reply.
So I think the NULL frame cannot be prohibited, If one slot want to send frame, but not each cycle, Right?
Because in the cycle not match filter, null frame must be transmitted, Right?
petervlna
How many nodes are you using?
Can you share on which slots the nodes are transmitting/receiving a what are their key frames of those nodes and what number has null frame.
Peter
Lyn
Thanks for your response.
As one flexray node on a car, my ecu communicate with many other ecus.
I attached the flexray log below(NULLFRAME.png).
You can see that this frame is expeceted to transmit at slot 23, cycle (1,9,17,25...)
But at other cycles, it also transmit null frame.
Cycle filter function seems not work any more.
I am so confused about this...
petervlna
Could you share the configuration of transmit message buffer which is transmitting the null frame?
Is it static or dynamic slot?
Peter
Lyn
I added the register setting below. This record is exported by s32 studio.
And problem occurs at static slot.
MVR: 0xA568 @ffe50000
MCR: 0x8800 @ffe50002
SYMBADHR: 0x4005 @ffe50004
SYMBADLR: 0xB1B0 @ffe50006
STBSCR: 0x0000 @ffe50008
MBDSR: 0x7F10 @ffe5000c
MBSSUTR: 0x5977 @ffe5000e
PEDRAR: 0x0000 @ffe50010
PEDRDR: 0x0000 @ffe50012
POCR: 0x0008 @ffe50014
GIFER: 0x1000 @ffe50016
PIFR0: 0x0000 @ffe50018
PIFR1: 0x1000 @ffe5001a
PIER0: 0x0000 @ffe5001c
PIER1: 0x0000 @ffe5001e
CHIERFR: 0x0000 @ffe50020
MBIVEC: 0x0000 @ffe50022
CASERCR: 0x0000 @ffe50024
CBSERCR: 0x0000 @ffe50026
PSR0: 0x2302 @ffe50028
PSR1: 0x0000 @ffe5002a
PSR2: 0x0000 @ffe5002c
PSR3: 0x0020 @ffe5002e
MTCTR: 0x0000 @ffe50030
CYCTR: 0x0000 @ffe50032
SLTCTAR: 0x0000 @ffe50034
SLTCTBR: 0x0000 @ffe50036
RTCORVR: 0x0000 @ffe50038
OFCORVR: 0x0000 @ffe5003a
CIFR: 0x00D1 @ffe5003c
SYMATOR: 0x0006 @ffe5003e
SFCNTR: 0x0000 @ffe50040
SFTOR: 0x0000 @ffe50042
SFTCCSR: 0x0000 @ffe50044
SFIDRFR: 0x0000 @ffe50046
SFIDAFVR: 0x0000 @ffe50048
SFIDAFMR: 0x0000 @ffe5004a
NMVR0: 0x0000 @ffe5004c
NMVR1: 0x0000 @ffe5004e
NMVR2: 0x0000 @ffe50050
NMVR3: 0x0000 @ffe50052
NMVR4: 0x0000 @ffe50054
NMVR5: 0x0000 @ffe50056
NMVLR: 0x0000 @ffe50058
TICCR: 0x0000 @ffe5005a
TI1CYSR: 0x0000 @ffe5005c
TI1MTOR: 0x0000 @ffe5005e
TI2CR0_ABS: 0x0000 @ffe50060
TI2CR0_REL: 0x0000 @ffe50060
TI2CR1_ABS: 0x0000 @ffe50062
TI2CR1_REL: 0x0000 @ffe50062
SSSR: 0x0000 @ffe50064
SSCCR: 0x0000 @ffe50066
SSR0: 0x0020 @ffe50068
SSR1: 0x0000 @ffe5006a
SSR2: 0x0020 @ffe5006c
SSR3: 0x0000 @ffe5006e
SSR4: 0x0020 @ffe50070
SSR5: 0x0000 @ffe50072
SSR6: 0x0020 @ffe50074
SSR7: 0x0000 @ffe50076
SSCR0: 0x0000 @ffe50078
SSCR1: 0x0000 @ffe5007a
SSCR2: 0x0000 @ffe5007c
SSCR3: 0x0000 @ffe5007e
MTSACFR: 0x0000 @ffe50080
MTSBCFR: 0x0000 @ffe50082
RSBIR: 0x307B @ffe50084
RFWMSR: 0x0000 @ffe50086
RFSIR: 0x0000 @ffe50088
RFDSR: 0x0000 @ffe5008a
RFARIR: 0x0000 @ffe5008c
RFBRIR: 0x0000 @ffe5008e
RFMIDAFVR: 0x0000 @ffe50090
RFMIDAFMR: 0x0000 @ffe50092
RFFIDRFVR: 0x0000 @ffe50094
RFFIDRFMR: 0x0000 @ffe50096
RFRFCFR: 0x0000 @ffe50098
RFRFCTR: 0x0000 @ffe5009a
LDTXSLAR: 0x0000 @ffe5009c
LDTXSLBR: 0x0000 @ffe5009e
PCR0: 0x203D @ffe500a0
PCR1: 0x134B @ffe500a2
PCR2: 0x183C @ffe500a4
PCR3: 0xDC4A @ffe500a6
PCR4: 0xAD2D @ffe500a8
PCR5: 0x9F3B @ffe500aa
PCR6: 0x000B @ffe500ac
PCR7: 0x1994 @ffe500ae
PCR8: 0xEAB4 @ffe500b0
PCR9: 0x8169 @ffe500b2
PCR10: 0x1388 @ffe500b4
PCR11: 0xD375 @ffe500b6
PCR12: 0x16D3 @ffe500b8
PCR13: 0x2033 @ffe500ba
PCR14: 0x4B26 @ffe500bc
PCR15: 0x1F32 @ffe500be
PCR16: 0x160C @ffe500c0
PCR17: 0x3E63 @ffe500c2
PCR18: 0xC004 @ffe500c4
PCR19: 0x1990 @ffe500c6
PCR20: 0x1F1F @ffe500c8
PCR21: 0x001B @ffe500ca
PCR22: 0x0D33 @ffe500cc
PCR23: 0x0D40 @ffe500ce
PCR24: 0x17F3 @ffe500d0
PCR25: 0x0AE7 @ffe500d2
PCR26: 0x0D33 @ffe500d4
PCR27: 0x0F99 @ffe500d6
PCR28: 0x0013 @ffe500d8
PCR29: 0x0080 @ffe500da
PCR30: 0x0008 @ffe500dc
STPWHR: 0x0000 @ffe500de
STPWLR: 0x0000 @ffe500e0
PEOER: 0x0000 @ffe500e2
RFSDOR: 0x0000 @ffe500e6
RFSYMBADHR: 0x0000 @ffe500e8
RFSYMBADLR: 0x0000 @ffe500ea
RFPTR: 0x0000 @ffe500ec
RFFLPCR: 0x0000 @ffe500ee
EEIFER: 0x0000 @ffe500f0
EERICR: 0x0000 @ffe500f2
EERAR: 0x7000 @ffe500f4
EERDR: 0x0000 @ffe500f6
EERCR: 0x0000 @ffe500f8
EEIAR: 0x0000 @ffe500fa
EEIDR: 0x0000 @ffe500fc
EEICR: 0x0000 @ffe500fe
MBCCSR0: 0x0004 @ffe50800
MBCCFR0: 0x51C0 @ffe50802
MBFIDR0: 0x000D @ffe50804
MBIDXR0: 0x0000 @ffe50806
MBCCSR1: 0x0004 @ffe50808
MBCCFR1: 0x51C1 @ffe5080a
MBFIDR1: 0x000D @ffe5080c
MBIDXR1: 0x0001 @ffe5080e
MBCCSR2: 0x0004 @ffe50810
MBCCFR2: 0x51C3 @ffe50812
MBFIDR2: 0x000D @ffe50814
MBIDXR2: 0x0002 @ffe50816
MBCCSR3: 0x0004 @ffe50818
MBCCFR3: 0x51C5 @ffe5081a
MBFIDR3: 0x000D @ffe5081c
MBIDXR3: 0x0003 @ffe5081e
MBCCSR4: 0x0004 @ffe50820
MBCCFR4: 0x51C6 @ffe50822
MBFIDR4: 0x000D @ffe50824
MBIDXR4: 0x0004 @ffe50826
MBCCSR5: 0x0004 @ffe50828
MBCCFR5: 0x51C1 @ffe5082a
MBFIDR5: 0x000E @ffe5082c
MBIDXR5: 0x0005 @ffe5082e
MBCCSR6: 0x0004 @ffe50830
MBCCFR6: 0x51C2 @ffe50832
MBFIDR6: 0x000E @ffe50834
MBIDXR6: 0x0006 @ffe50836
MBCCSR7: 0x0004 @ffe50838
MBCCFR7: 0x51C2 @ffe5083a
MBFIDR7: 0x000F @ffe5083c
MBIDXR7: 0x0007 @ffe5083e
MBCCSR8: 0x0004 @ffe50840
MBCCFR8: 0x51C3 @ffe50842
MBFIDR8: 0x000F @ffe50844
MBIDXR8: 0x0008 @ffe50846
MBCCSR9: 0x0004 @ffe50848
MBCCFR9: 0x51C6 @ffe5084a
MBFIDR9: 0x000F @ffe5084c
MBIDXR9: 0x0009 @ffe5084e
MBCCSR10: 0x0004 @ffe50850
MBCCFR10: 0x5FC0 @ffe50852
MBFIDR10: 0x006B @ffe50854
MBIDXR10: 0x000A @ffe50856
MBCCSR11: 0x0004 @ffe50858
MBCCFR11: 0x50C0 @ffe5085a
MBFIDR11: 0x000F @ffe5085c
MBIDXR11: 0x000B @ffe5085e
MBCCSR12: 0x0004 @ffe50860
MBCCFR12: 0x5000 @ffe50862
MBFIDR12: 0x001F @ffe50864
MBIDXR12: 0x000C @ffe50866
MBCCSR13: 0x0004 @ffe50868
MBCCFR13: 0x50C1 @ffe5086a
MBFIDR13: 0x000A @ffe5086c
MBIDXR13: 0x000D @ffe5086e
MBCCSR14: 0x0004 @ffe50870
MBCCFR14: 0x50C2 @ffe50872
MBFIDR14: 0x000A @ffe50874
MBIDXR14: 0x000E @ffe50876
MBCCSR15: 0x0004 @ffe50878
MBCCFR15: 0x51C0 @ffe5087a
MBFIDR15: 0x0020 @ffe5087c
MBIDXR15: 0x000F @ffe5087e
MBCCSR16: 0x0004 @ffe50880
MBCCFR16: 0x51C1 @ffe50882
MBFIDR16: 0x0020 @ffe50884
MBIDXR16: 0x0010 @ffe50886
MBCCSR17: 0x0004 @ffe50888
MBCCFR17: 0x51C2 @ffe5088a
MBFIDR17: 0x0020 @ffe5088c
MBIDXR17: 0x0011 @ffe5088e
MBCCSR18: 0x0004 @ffe50890
MBCCFR18: 0x51C3 @ffe50892
MBFIDR18: 0x0020 @ffe50894
MBIDXR18: 0x0012 @ffe50896
MBCCSR19: 0x0004 @ffe50898
MBCCFR19: 0x53C4 @ffe5089a
MBFIDR19: 0x0020 @ffe5089c
MBIDXR19: 0x0013 @ffe5089e
MBCCSR20: 0x0004 @ffe508a0
MBCCFR20: 0x53C5 @ffe508a2
MBFIDR20: 0x0020 @ffe508a4
MBIDXR20: 0x0014 @ffe508a6
MBCCSR21: 0x0004 @ffe508a8
MBCCFR21: 0x53C6 @ffe508aa
MBFIDR21: 0x0020 @ffe508ac
MBIDXR21: 0x0015 @ffe508ae
MBCCSR22: 0x0004 @ffe508b0
MBCCFR22: 0x50C2 @ffe508b2
MBFIDR22: 0x001E @ffe508b4
MBIDXR22: 0x0016 @ffe508b6
MBCCSR23: 0x0004 @ffe508b8
MBCCFR23: 0x53C7 @ffe508ba
MBFIDR23: 0x0020 @ffe508bc
MBIDXR23: 0x0017 @ffe508be
MBCCSR24: 0x0004 @ffe508c0
MBCCFR24: 0x5FCD @ffe508c2
MBFIDR24: 0x0020 @ffe508c4
MBIDXR24: 0x0018 @ffe508c6
MBCCSR25: 0x0004 @ffe508c8
MBCCFR25: 0x5FCC @ffe508ca
MBFIDR25: 0x0020 @ffe508cc
MBIDXR25: 0x0019 @ffe508ce
MBCCSR26: 0x0004 @ffe508d0
MBCCFR26: 0x50C3 @ffe508d2
MBFIDR26: 0x000A @ffe508d4
MBIDXR26: 0x001A @ffe508d6
MBCCSR27: 0x0004 @ffe508d8
MBCCFR27: 0x50C0 @ffe508da
MBFIDR27: 0x001E @ffe508dc
MBIDXR27: 0x001B @ffe508de
MBCCSR28: 0x0004 @ffe508e0
MBCCFR28: 0x50C1 @ffe508e2
MBFIDR28: 0x001E @ffe508e4
MBIDXR28: 0x001C @ffe508e6
MBCCSR29: 0x0004 @ffe508e8
MBCCFR29: 0x5FFE @ffe508ea
MBFIDR29: 0x0020 @ffe508ec
MBIDXR29: 0x001D @ffe508ee
MBCCSR30: 0x0004 @ffe508f0
MBCCFR30: 0x51C3 @ffe508f2
MBFIDR30: 0x001E @ffe508f4
MBIDXR30: 0x001E @ffe508f6
MBCCSR31: 0x0004 @ffe508f8
MBCCFR31: 0x51C7 @ffe508fa
MBFIDR31: 0x001E @ffe508fc
MBIDXR31: 0x001F @ffe508fe
MBCCSR32: 0x0004 @ffe50900
MBCCFR32: 0x50C0 @ffe50902
MBFIDR32: 0x000A @ffe50904
MBIDXR32: 0x0020 @ffe50906
MBCCSR33: 0x1005 @ffe50908
MBCCFR33: 0x5FC0 @ffe5090a
MBFIDR33: 0x007B @ffe5090c
MBIDXR33: 0x0021 @ffe5090e
MBCCSR34: 0x1005 @ffe50910
MBCCFR34: 0x50C0 @ffe50912
MBFIDR34: 0x0011 @ffe50914
MBIDXR34: 0x0022 @ffe50916
MBCCSR35: 0x1005 @ffe50918
MBCCFR35: 0x5041 @ffe5091a
MBFIDR35: 0x0011 @ffe5091c
MBIDXR35: 0x0023 @ffe5091e
MBCCSR36: 0x1005 @ffe50920
MBCCFR36: 0x53C4 @ffe50922
MBFIDR36: 0x0010 @ffe50924
MBIDXR36: 0x0024 @ffe50926
MBCCSR37: 0x1005 @ffe50928
MBCCFR37: 0x51C0 @ffe5092a
MBFIDR37: 0x0010 @ffe5092c
MBIDXR37: 0x0025 @ffe5092e
MBCCSR38: 0x1005 @ffe50930
MBCCFR38: 0x5FCC @ffe50932
MBFIDR38: 0x0010 @ffe50934
MBIDXR38: 0x0026 @ffe50936
MBCCSR39: 0x1005 @ffe50938
MBCCFR39: 0x53C1 @ffe5093a
MBFIDR39: 0x0010 @ffe5093c
MBIDXR39: 0x0027 @ffe5093e
MBCCSR40: 0x1005 @ffe50940
MBCCFR40: 0x5040 @ffe50942
MBFIDR40: 0x0019 @ffe50944
MBIDXR40: 0x0028 @ffe50946
MBCCSR41: 0x1005 @ffe50948
MBCCFR41: 0x5040 @ffe5094a
MBFIDR41: 0x001A @ffe5094c
MBIDXR41: 0x0029 @ffe5094e
MBCCSR42: 0x1005 @ffe50950
MBCCFR42: 0x51C1 @ffe50952
MBFIDR42: 0x001B @ffe50954
MBIDXR42: 0x002A @ffe50956
MBCCSR43: 0x1005 @ffe50958
MBCCFR43: 0x53CF @ffe5095a
MBFIDR43: 0x001B @ffe5095c
MBIDXR43: 0x002B @ffe5095e
MBCCSR44: 0x1005 @ffe50960
MBCCFR44: 0x5041 @ffe50962
MBFIDR44: 0x0019 @ffe50964
MBIDXR44: 0x002C @ffe50966
MBCCSR45: 0x1005 @ffe50968
MBCCFR45: 0x50C0 @ffe5096a
MBFIDR45: 0x001B @ffe5096c
MBIDXR45: 0x002D @ffe5096e
MBCCSR46: 0x1005 @ffe50970
MBCCFR46: 0x53C6 @ffe50972
MBFIDR46: 0x001B @ffe50974
MBIDXR46: 0x002E @ffe50976
MBCCSR47: 0x1005 @ffe50978
MBCCFR47: 0x53C7 @ffe5097a
MBFIDR47: 0x001B @ffe5097c
MBIDXR47: 0x002F @ffe5097e
MBCCSR48: 0x1005 @ffe50980
MBCCFR48: 0x51C2 @ffe50982
MBFIDR48: 0x001B @ffe50984
MBIDXR48: 0x0030 @ffe50986
MBCCSR49: 0x1005 @ffe50988
MBCCFR49: 0x5041 @ffe5098a
MBFIDR49: 0x001A @ffe5098c
MBIDXR49: 0x0031 @ffe5098e
MBCCSR50: 0x1005 @ffe50990
MBCCFR50: 0x5FDE @ffe50992
MBFIDR50: 0x001B @ffe50994
MBIDXR50: 0x0032 @ffe50996
MBCCSR51: 0x1005 @ffe50998
MBCCFR51: 0x57CE @ffe5099a
MBFIDR51: 0x001B @ffe5099c
MBIDXR51: 0x0033 @ffe5099e
MBCCSR52: 0x1005 @ffe509a0
MBCCFR52: 0x5FFE @ffe509a2
MBFIDR52: 0x001B @ffe509a4
MBIDXR52: 0x0034 @ffe509a6
MBCCSR53: 0x1005 @ffe509a8
MBCCFR53: 0x51C3 @ffe509aa
MBFIDR53: 0x001B @ffe509ac
MBIDXR53: 0x0035 @ffe509ae
MBCCSR54: 0x1005 @ffe509b0
MBCCFR54: 0x50C1 @ffe509b2
MBFIDR54: 0x001C @ffe509b4
MBIDXR54: 0x0036 @ffe509b6
MBCCSR55: 0x1005 @ffe509b8
MBCCFR55: 0x50C0 @ffe509ba
MBFIDR55: 0x0017 @ffe509bc
MBIDXR55: 0x0037 @ffe509be
MBCCSR56: 0x1005 @ffe509c0
MBCCFR56: 0x51C1 @ffe509c2
MBFIDR56: 0x006E @ffe509c4
MBIDXR56: 0x0038 @ffe509c6
MBCCSR57: 0x1005 @ffe509c8
MBCCFR57: 0x51C2 @ffe509ca
MBFIDR57: 0x006E @ffe509cc
MBIDXR57: 0x0039 @ffe509ce
MBCCSR58: 0x1005 @ffe509d0
MBCCFR58: 0x51C3 @ffe509d2
MBFIDR58: 0x006E @ffe509d4
MBIDXR58: 0x003A @ffe509d6
MBCCSR59: 0x1005 @ffe509d8
MBCCFR59: 0x51C0 @ffe509da
MBFIDR59: 0x006E @ffe509dc
MBIDXR59: 0x003B @ffe509de
MBCCSR60: 0x1005 @ffe509e0
MBCCFR60: 0x51C6 @ffe509e2
MBFIDR60: 0x006E @ffe509e4
MBIDXR60: 0x003C @ffe509e6
MBCCSR61: 0x1005 @ffe509e8
MBCCFR61: 0x51C5 @ffe509ea
MBFIDR61: 0x006E @ffe509ec
MBIDXR61: 0x003D @ffe509ee
MBCCSR62: 0x1005 @ffe509f0
MBCCFR62: 0x50C3 @ffe509f2
MBFIDR62: 0x0018 @ffe509f4
MBIDXR62: 0x003E @ffe509f6
MBCCSR63: 0x1005 @ffe509f8
MBCCFR63: 0x53CF @ffe509fa
MBFIDR63: 0x001C @ffe509fc
MBIDXR63: 0x003F @ffe509fe
MBCCSR64: 0x1005 @ffe50a00
MBCCFR64: 0x51C5 @ffe50a02
MBFIDR64: 0x001B @ffe50a04
MBIDXR64: 0x0040 @ffe50a06
MBCCSR65: 0x1005 @ffe50a08
MBCCFR65: 0x57C8 @ffe50a0a
MBFIDR65: 0x001C @ffe50a0c
MBIDXR65: 0x0041 @ffe50a0e
MBCCSR66: 0x1005 @ffe50a10
MBCCFR66: 0x51C4 @ffe50a12
MBFIDR66: 0x006E @ffe50a14
MBIDXR66: 0x0042 @ffe50a16
MBCCSR67: 0x1005 @ffe50a18
MBCCFR67: 0x51C7 @ffe50a1a
MBFIDR67: 0x006E @ffe50a1c
MBIDXR67: 0x0043 @ffe50a1e
MBCCSR68: 0x1005 @ffe50a20
MBCCFR68: 0x51C0 @ffe50a22
MBFIDR68: 0x006F @ffe50a24
MBIDXR68: 0x0044 @ffe50a26
MBCCSR69: 0x1005 @ffe50a28
MBCCFR69: 0x51C1 @ffe50a2a
MBFIDR69: 0x006F @ffe50a2c
MBIDXR69: 0x0045 @ffe50a2e
MBCCSR70: 0x1005 @ffe50a30
MBCCFR70: 0x51C3 @ffe50a32
MBFIDR70: 0x001C @ffe50a34
MBIDXR70: 0x0046 @ffe50a36
MBCCSR71: 0x1005 @ffe50a38
MBCCFR71: 0x51C2 @ffe50a3a
MBFIDR71: 0x006F @ffe50a3c
MBIDXR71: 0x0047 @ffe50a3e
MBCCSR72: 0x1005 @ffe50a40
MBCCFR72: 0x51C3 @ffe50a42
MBFIDR72: 0x006F @ffe50a44
MBIDXR72: 0x0048 @ffe50a46
MBCCSR73: 0x1005 @ffe50a48
MBCCFR73: 0x53C2 @ffe50a4a
MBFIDR73: 0x001C @ffe50a4c
MBIDXR73: 0x0049 @ffe50a4e
MBCCSR74: 0x1005 @ffe50a50
MBCCFR74: 0x51C4 @ffe50a52
MBFIDR74: 0x006F @ffe50a54
MBIDXR74: 0x004A @ffe50a56
MBCCSR75: 0x1005 @ffe50a58
MBCCFR75: 0x51C1 @ffe50a5a
MBFIDR75: 0x0017 @ffe50a5c
MBIDXR75: 0x004B @ffe50a5e
MBCCSR76: 0x1005 @ffe50a60
MBCCFR76: 0x51C0 @ffe50a62
MBFIDR76: 0x0063 @ffe50a64
MBIDXR76: 0x004C @ffe50a66
MBCCSR77: 0x1005 @ffe50a68
MBCCFR77: 0x51C1 @ffe50a6a
MBFIDR77: 0x0063 @ffe50a6c
MBIDXR77: 0x004D @ffe50a6e
MBCCSR78: 0x1005 @ffe50a70
MBCCFR78: 0x51C2 @ffe50a72
MBFIDR78: 0x0063 @ffe50a74
MBIDXR78: 0x004E @ffe50a76
MBCCSR79: 0x1005 @ffe50a78
MBCCFR79: 0x51C3 @ffe50a7a
MBFIDR79: 0x0063 @ffe50a7c
MBIDXR79: 0x004F @ffe50a7e
MBCCSR80: 0x1005 @ffe50a80
MBCCFR80: 0x51C4 @ffe50a82
MBFIDR80: 0x0063 @ffe50a84
MBIDXR80: 0x0050 @ffe50a86
MBCCSR81: 0x1005 @ffe50a88
MBCCFR81: 0x51C5 @ffe50a8a
MBFIDR81: 0x0063 @ffe50a8c
MBIDXR81: 0x0051 @ffe50a8e
MBCCSR82: 0x1005 @ffe50a90
MBCCFR82: 0x51C6 @ffe50a92
MBFIDR82: 0x0063 @ffe50a94
MBIDXR82: 0x0052 @ffe50a96
MBCCSR83: 0x1005 @ffe50a98
MBCCFR83: 0x51C7 @ffe50a9a
MBFIDR83: 0x0063 @ffe50a9c
MBIDXR83: 0x0053 @ffe50a9e
MBCCSR84: 0x1005 @ffe50aa0
MBCCFR84: 0x53C0 @ffe50aa2
MBFIDR84: 0x001C @ffe50aa4
MBIDXR84: 0x0054 @ffe50aa6
MBCCSR85: 0x1005 @ffe50aa8
MBCCFR85: 0x57C2 @ffe50aaa
MBFIDR85: 0x0017 @ffe50aac
MBIDXR85: 0x0055 @ffe50aae
MBCCSR86: 0x1005 @ffe50ab0
MBCCFR86: 0x51C3 @ffe50ab2
MBFIDR86: 0x0017 @ffe50ab4
MBIDXR86: 0x0056 @ffe50ab6
MBCCSR87: 0x1005 @ffe50ab8
MBCCFR87: 0x51C5 @ffe50aba
MBFIDR87: 0x0017 @ffe50abc
MBIDXR87: 0x0057 @ffe50abe
MBCCSR88: 0x1005 @ffe50ac0
MBCCFR88: 0x53C6 @ffe50ac2
MBFIDR88: 0x0017 @ffe50ac4
MBIDXR88: 0x0058 @ffe50ac6
MBCCSR89: 0x1005 @ffe50ac8
MBCCFR89: 0x50C0 @ffe50aca
MBFIDR89: 0x0004 @ffe50acc
MBIDXR89: 0x0059 @ffe50ace
MBCCSR90: 0x0004 @ffe50ad0
MBCCFR90: 0x5000 @ffe50ad2
MBFIDR90: 0x0001 @ffe50ad4
MBIDXR90: 0x005A @ffe50ad6
MBCCSR91: 0x0004 @ffe50ad8
MBCCFR91: 0x50C1 @ffe50ada
MBFIDR91: 0x0003 @ffe50adc
MBIDXR91: 0x005B @ffe50ade
MBCCSR92: 0x0004 @ffe50ae0
MBCCFR92: 0x5040 @ffe50ae2
MBFIDR92: 0x002A @ffe50ae4
MBIDXR92: 0x005C @ffe50ae6
MBCCSR93: 0x0004 @ffe50ae8
MBCCFR93: 0x50C2 @ffe50aea
MBFIDR93: 0x0003 @ffe50aec
MBIDXR93: 0x005D @ffe50aee
MBCCSR94: 0x0004 @ffe50af0
MBCCFR94: 0x51C0 @ffe50af2
MBFIDR94: 0x002B @ffe50af4
MBIDXR94: 0x005E @ffe50af6
MBCCSR95: 0x0004 @ffe50af8
MBCCFR95: 0x53C1 @ffe50afa
MBFIDR95: 0x002B @ffe50afc
MBIDXR95: 0x005F @ffe50afe
MBCCSR96: 0x0004 @ffe50b00
MBCCFR96: 0x53CE @ffe50b02
MBFIDR96: 0x002B @ffe50b04
MBIDXR96: 0x0060 @ffe50b06
MBCCSR97: 0x0004 @ffe50b08
MBCCFR97: 0x53C2 @ffe50b0a
MBFIDR97: 0x002B @ffe50b0c
MBIDXR97: 0x0061 @ffe50b0e
MBCCSR98: 0x0004 @ffe50b10
MBCCFR98: 0x5FE5 @ffe50b12
MBFIDR98: 0x002B @ffe50b14
MBIDXR98: 0x0062 @ffe50b16
MBCCSR99: 0x0004 @ffe50b18
MBCCFR99: 0x57DC @ffe50b1a
MBFIDR99: 0x002B @ffe50b1c
MBIDXR99: 0x0063 @ffe50b1e
MBCCSR100: 0x0004 @ffe50b20
MBCCFR100: 0x53C6 @ffe50b22
MBFIDR100: 0x002B @ffe50b24
MBIDXR100: 0x0064 @ffe50b26
MBCCSR101: 0x0004 @ffe50b28
MBCCFR101: 0x50C3 @ffe50b2a
MBFIDR101: 0x0003 @ffe50b2c
MBIDXR101: 0x0065 @ffe50b2e
MBCCSR102: 0x0004 @ffe50b30
MBCCFR102: 0x53C4 @ffe50b32
MBFIDR102: 0x002B @ffe50b34
MBIDXR102: 0x0066 @ffe50b36
MBCCSR103: 0x0004 @ffe50b38
MBCCFR103: 0x53CA @ffe50b3a
MBFIDR103: 0x002B @ffe50b3c
MBIDXR103: 0x0067 @ffe50b3e
MBCCSR104: 0x0004 @ffe50b40
MBCCFR104: 0x5041 @ffe50b42
MBFIDR104: 0x002A @ffe50b44
MBIDXR104: 0x0068 @ffe50b46
MBCCSR105: 0x0004 @ffe50b48
MBCCFR105: 0x5000 @ffe50b4a
MBFIDR105: 0x0074 @ffe50b4c
MBIDXR105: 0x0069 @ffe50b4e
MBCCSR106: 0x0004 @ffe50b50
MBCCFR106: 0x51C3 @ffe50b52
MBFIDR106: 0x002B @ffe50b54
MBIDXR106: 0x006A @ffe50b56
MBCCSR107: 0x0004 @ffe50b58
MBCCFR107: 0x5000 @ffe50b5a
MBFIDR107: 0x0077 @ffe50b5c
MBIDXR107: 0x006B @ffe50b5e
MBCCSR108: 0x0004 @ffe50b60
MBCCFR108: 0x5000 @ffe50b62
MBFIDR108: 0x0071 @ffe50b64
MBIDXR108: 0x006C @ffe50b66
MBCCSR109: 0x0004 @ffe50b68
MBCCFR109: 0x51C7 @ffe50b6a
MBFIDR109: 0x002B @ffe50b6c
MBIDXR109: 0x006D @ffe50b6e
MBCCSR110: 0x0004 @ffe50b70
MBCCFR110: 0x53C5 @ffe50b72
MBFIDR110: 0x002C @ffe50b74
MBIDXR110: 0x006E @ffe50b76
MBCCSR111: 0x0004 @ffe50b78
MBCCFR111: 0x53C4 @ffe50b7a
MBFIDR111: 0x002C @ffe50b7c
MBIDXR111: 0x006F @ffe50b7e
MBCCSR112: 0x0004 @ffe50b80
MBCCFR112: 0x53C7 @ffe50b82
MBFIDR112: 0x002C @ffe50b84
MBIDXR112: 0x0070 @ffe50b86
MBCCSR113: 0x0004 @ffe50b88
MBCCFR113: 0x53C0 @ffe50b8a
MBFIDR113: 0x002C @ffe50b8c
MBIDXR113: 0x0071 @ffe50b8e
MBCCSR114: 0x0004 @ffe50b90
MBCCFR114: 0x50C0 @ffe50b92
MBFIDR114: 0x0003 @ffe50b94
MBIDXR114: 0x0072 @ffe50b96
MBCCSR115: 0x0004 @ffe50b98
MBCCFR115: 0x57CC @ffe50b9a
MBFIDR115: 0x002B @ffe50b9c
MBIDXR115: 0x0073 @ffe50b9e
MBCCSR116: 0x0004 @ffe50ba0
MBCCFR116: 0x5FC0 @ffe50ba2
MBFIDR116: 0x007F @ffe50ba4
MBIDXR116: 0x0074 @ffe50ba6
MBCCSR117: 0x0000 @ffe50ba8
MBCCFR117: 0x0000 @ffe50baa
MBFIDR117: 0x0000 @ffe50bac
MBIDXR117: 0x0000 @ffe50bae
MBCCSR118: 0x0000 @ffe50bb0
MBCCFR118: 0x0000 @ffe50bb2
MBFIDR118: 0x0000 @ffe50bb4
MBIDXR118: 0x0000 @ffe50bb6
MBCCSR119: 0x0000 @ffe50bb8
MBCCFR119: 0x0000 @ffe50bba
MBFIDR119: 0x0000 @ffe50bbc
MBIDXR119: 0x0000 @ffe50bbe
MBCCSR120: 0x0000 @ffe50bc0
MBCCFR120: 0x0000 @ffe50bc2
MBFIDR120: 0x0000 @ffe50bc4
MBIDXR120: 0x0000 @ffe50bc6
MBCCSR121: 0x0000 @ffe50bc8
MBCCFR121: 0x0000 @ffe50bca
MBFIDR121: 0x0000 @ffe50bcc
MBIDXR121: 0x0000 @ffe50bce
MBCCSR122: 0x0000 @ffe50bd0
MBCCFR122: 0x0000 @ffe50bd2
MBFIDR122: 0x0000 @ffe50bd4
MBIDXR122: 0x0000 @ffe50bd6
MBCCSR123: 0x0000 @ffe50bd8
MBCCFR123: 0x0000 @ffe50bda
MBFIDR123: 0x0000 @ffe50bdc
MBIDXR123: 0x0000 @ffe50bde
MBCCSR124: 0x0000 @ffe50be0
MBCCFR124: 0x0000 @ffe50be2
MBFIDR124: 0x0000 @ffe50be4
MBIDXR124: 0x0000 @ffe50be6
MBCCSR125: 0x0000 @ffe50be8
MBCCFR125: 0x0000 @ffe50bea
MBFIDR125: 0x0000 @ffe50bec
MBIDXR125: 0x0000 @ffe50bee
MBCCSR126: 0x0000 @ffe50bf0
MBCCFR126: 0x0000 @ffe50bf2
MBFIDR126: 0x0000 @ffe50bf4
MBIDXR126: 0x0000 @ffe50bf6
MBCCSR127: 0x0000 @ffe50bf8
MBCCFR127: 0x0000 @ffe50bfa
MBFIDR127: 0x0000 @ffe50bfc
MBIDXR127: 0x0000 @ffe50bfe
MBDOR0: 0x03E0 @ffe51000
MBDOR1: 0x0400 @ffe51002
MBDOR2: 0x0420 @ffe51004
MBDOR3: 0x0440 @ffe51006
MBDOR4: 0x0460 @ffe51008
MBDOR5: 0x0480 @ffe5100a
MBDOR6: 0x04A0 @ffe5100c
MBDOR7: 0x04C0 @ffe5100e
MBDOR8: 0x04E0 @ffe51010
MBDOR9: 0x0500 @ffe51012
MBDOR10: 0x0F20 @ffe51014
MBDOR11: 0x0520 @ffe51016
MBDOR12: 0x0540 @ffe51018
MBDOR13: 0x0560 @ffe5101a
MBDOR14: 0x0580 @ffe5101c
MBDOR15: 0x05A0 @ffe5101e
MBDOR16: 0x05C0 @ffe51020
MBDOR17: 0x05E0 @ffe51022
MBDOR18: 0x0600 @ffe51024
MBDOR19: 0x0620 @ffe51026
MBDOR20: 0x0640 @ffe51028
MBDOR21: 0x0660 @ffe5102a
MBDOR22: 0x0680 @ffe5102c
MBDOR23: 0x06A0 @ffe5102e
MBDOR24: 0x06C0 @ffe51030
MBDOR25: 0x06E0 @ffe51032
MBDOR26: 0x0700 @ffe51034
MBDOR27: 0x0720 @ffe51036
MBDOR28: 0x0740 @ffe51038
MBDOR29: 0x0760 @ffe5103a
MBDOR30: 0x0780 @ffe5103c
MBDOR31: 0x07A0 @ffe5103e
MBDOR32: 0x07C0 @ffe51040
MBDOR33: 0x1020 @ffe51042
MBDOR34: 0x07E0 @ffe51044
MBDOR35: 0x0800 @ffe51046
MBDOR36: 0x0820 @ffe51048
MBDOR37: 0x0840 @ffe5104a
MBDOR38: 0x0860 @ffe5104c
MBDOR39: 0x0880 @ffe5104e
MBDOR40: 0x08A0 @ffe51050
MBDOR41: 0x08C0 @ffe51052
MBDOR42: 0x08E0 @ffe51054
MBDOR43: 0x0900 @ffe51056
MBDOR44: 0x0920 @ffe51058
MBDOR45: 0x0940 @ffe5105a
MBDOR46: 0x0960 @ffe5105c
MBDOR47: 0x0980 @ffe5105e
MBDOR48: 0x09A0 @ffe51060
MBDOR49: 0x09C0 @ffe51062
MBDOR50: 0x09E0 @ffe51064
MBDOR51: 0x0A00 @ffe51066
MBDOR52: 0x0A20 @ffe51068
MBDOR53: 0x0A40 @ffe5106a
MBDOR54: 0x0A60 @ffe5106c
MBDOR55: 0x0A80 @ffe5106e
MBDOR56: 0x1120 @ffe51070
MBDOR57: 0x1220 @ffe51072
MBDOR58: 0x1320 @ffe51074
MBDOR59: 0x1420 @ffe51076
MBDOR60: 0x1520 @ffe51078
MBDOR61: 0x1620 @ffe5107a
MBDOR62: 0x0AA0 @ffe5107c
MBDOR63: 0x0AC0 @ffe5107e
MBDOR64: 0x0AE0 @ffe51080
MBDOR65: 0x0B00 @ffe51082
MBDOR66: 0x1720 @ffe51084
MBDOR67: 0x1820 @ffe51086
MBDOR68: 0x1920 @ffe51088
MBDOR69: 0x1A20 @ffe5108a
MBDOR70: 0x0B20 @ffe5108c
MBDOR71: 0x1B20 @ffe5108e
MBDOR72: 0x1C20 @ffe51090
MBDOR73: 0x0B40 @ffe51092
MBDOR74: 0x1D20 @ffe51094
MBDOR75: 0x0B60 @ffe51096
MBDOR76: 0x1E20 @ffe51098
MBDOR77: 0x1F20 @ffe5109a
MBDOR78: 0x2020 @ffe5109c
MBDOR79: 0x2120 @ffe5109e
MBDOR80: 0x2220 @ffe510a0
MBDOR81: 0x2320 @ffe510a2
MBDOR82: 0x2420 @ffe510a4
MBDOR83: 0x2520 @ffe510a6
MBDOR84: 0x0B80 @ffe510a8
MBDOR85: 0x0BA0 @ffe510aa
MBDOR86: 0x0BC0 @ffe510ac
MBDOR87: 0x0BE0 @ffe510ae
MBDOR88: 0x0C00 @ffe510b0
MBDOR89: 0x0C20 @ffe510b2
MBDOR90: 0x0C40 @ffe510b4
MBDOR91: 0x0C60 @ffe510b6
MBDOR92: 0x0C80 @ffe510b8
MBDOR93: 0x0CA0 @ffe510ba
MBDOR94: 0x0CC0 @ffe510bc
MBDOR95: 0x0CE0 @ffe510be
MBDOR96: 0x0D00 @ffe510c0
MBDOR97: 0x0D20 @ffe510c2
MBDOR98: 0x0D40 @ffe510c4
MBDOR99: 0x0D60 @ffe510c6
MBDOR100: 0x0D80 @ffe510c8
MBDOR101: 0x0DA0 @ffe510ca
MBDOR102: 0x0DC0 @ffe510cc
MBDOR103: 0x0DE0 @ffe510ce
MBDOR104: 0x0E00 @ffe510d0
MBDOR105: 0x2620 @ffe510d2
MBDOR106: 0x0E20 @ffe510d4
MBDOR107: 0x2720 @ffe510d6
MBDOR108: 0x2820 @ffe510d8
MBDOR109: 0x0E40 @ffe510da
MBDOR110: 0x0E60 @ffe510dc
MBDOR111: 0x0E80 @ffe510de
MBDOR112: 0x0EA0 @ffe510e0
MBDOR113: 0x0EC0 @ffe510e2
MBDOR114: 0x0EE0 @ffe510e4
MBDOR115: 0x0F00 @ffe510e6
MBDOR116: 0x2920 @ffe510e8
MBDOR117: 0x0000 @ffe510ea
MBDOR118: 0x0000 @ffe510ec
MBDOR119: 0x0000 @ffe510ee
MBDOR120: 0x2D20 @ffe510f0
MBDOR121: 0x2D40 @ffe510f2
MBDOR122: 0x2D60 @ffe510f4
MBDOR123: 0x2E60 @ffe510f6
MBDOR124: 0x0000 @ffe510f8
MBDOR125: 0x0000 @ffe510fa
MBDOR126: 0x0000 @ffe510fc
MBDOR127: 0x0000 @ffe510fe
MBDOR128: 0x0000 @ffe51100
MBDOR129: 0x0000 @ffe51102
MBDOR130: 0x0000 @ffe51104
MBDOR131: 0x0000 @ffe51106
LEETR0: 0x0000 @ffe51108
LEETR1: 0x0000 @ffe5110a
LEETR2: 0x0000 @ffe5110c
LEETR3: 0x0000 @ffe5110e
LEETR4: 0x0000 @ffe51110
LEETR5: 0x0000 @ffe51112
