Flexcan
Flexcan
3,521 次查看
natarajmani
hi friend..
I am working with MPC5674f..could you send  Flex CAN sample code for MPC5674f...what is difference between FLEXCAN & TOUCAN & CAN2.0B..what is reason to use Rx 14 Mask & Rx 15 Mask only..
4 回复数
2,995 次查看
lukaszadrapa
see please attached example.
TouCAN is older module used on older devices. FlexCAN is used on new devices - there are more features, more message buffers... Both support CAN 2.0A and 2.0B specification. That means standard 11-bit and extended 29-bit identifiers.
Lukas
2,995 次查看
natarajmani
Thank you friend,what is the difference between global acceptance filter and individual acceptance filter ..and could you please send me flexcan code for  MPC5674f  using extended frame format..Please do the needful..
2,996 次查看
lukaszadrapa
attached is the same project modified to use extended identifier.
Lukas
2,995 次查看
natarajmani
Thank you friend..how to receive the message using RX FIFO ..send me sample code ....
