Exception IVOR33 in MPC5777C Floating-Point Operations and Exception Conditions.
2,870件の閲覧回数
kwru
I am performing floating-point operations using the MPC5777C. I am encountering Exception IVOR33 and would like to inquire about it.
First, my MSR setting is as follows:
MSR = 0x0202B000 (SPE, FP enabled)
The test data used is:
FLT_MAX = 3.403e+38
FLT_MIN = 1.175e-38
FLT_TRUE_MIN = 1.401e-45
dNum -> double
fNum -> float
Case 1:
dNum = FLT_MAX * 2;
fNum = (float)dNum;
→ Exception did not occur
Case 2:
dNum = FLT_MIN / 2.;
fNum = (float)dNum;
Case 3:
dNum = FLT_TRUE_MIN / 2;
fNum = (float)dNum;
Case 4:
fTmp = 1.e+30f;
fNum = fTmp * fTmp;
Case 5:
fTmp = 1.e-20f;
fNum = fTmp * fTmp;
→ Exception occurred!
Why does an exception not occur in Case 1 when exceeding the upper limit?
Also, I would like to know the precise conditions under which the exception occurs.
タグ(1)
4 返答(返信)
2,840件の閲覧回数
davidtosenovjan
What is your setting of SPEFSCR register?
2,817件の閲覧回数
kwru
I configured FINVE/FDBZE/FUNFE/FOVFE using the SPESFCR register.
When I check the register, however, it shows SPESFCR = 0x0020303B (FINXS/FG/FX/FINVE/FDBZE/FUNFE/FRMC(11)).
It is strange that the FOVFE setting is not reflected even though I enabled it.
2,787件の閲覧回数
davidtosenovjan
I have tested it with MPC5674F having the same core (MPC5777C I don't available jut now) and I have set all bits in the register. I guess you could have some problem in your assembler code.
2,578件の閲覧回数
kwru
Thank you for your reply.
How was the SPESFCR register configured, and how was it actually set?
What exactly does it mean that all the tests were successful?
When the FOVFE in the SPESFCR register is enabled, does an exception occur in test case No. 1 above?
%3CLINGO-SUB%20id%3D%22lingo-sub-2247915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMPC5777C%20%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E6%BC%94%E7%AE%97%E3%81%8A%E3%82%88%E3%81%B3%E4%BE%8B%E5%A4%96%E6%9D%A1%E4%BB%B6%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E4%BE%8B%E5%A4%96%20IVOR33%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2247915%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMPC5777C%20%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E6%BC%94%E7%AE%97%E3%81%8A%E3%82%88%E3%81%B3%E4%BE%8B%E5%A4%96%E6%9D%A1%E4%BB%B6%E3%81%AB%E3%81%8A%E3%81%91%E3%82%8B%E4%BE%8B%E5%A4%96%20IVOR33%E3%80%82%3C%2FP%3E%3CP%3EMPC5777C%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E6%BC%94%E7%AE%97%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E4%BE%8B%E5%A4%96%20IVOR33%20%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%93%E3%82%8C%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E5%95%8F%E3%81%84%E5%90%88%E3%82%8F%E3%81%9B%E3%81%9F%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E7%A7%81%E3%81%AE%20MSR%20%E8%A8%AD%E5%AE%9A%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%20MSR%20%3D%200x0202B000%20(SPE%E3%80%81FP%20%E6%9C%89%E5%8A%B9)%3C%2FP%3E%3CP%3E%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%82%8B%E3%83%86%E3%82%B9%E3%83%88%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%20FLT_MAX%20%3D%203.403e%2B38%3CBR%20%2F%3E%20FLT_MIN%20%3D%201.175e-38%3CBR%20%2F%3EFLT_TRUE_MIN%20%3D%201.401e-45%3C%2FP%3E%3CP%3EdNum%20-%26gt%3B%20%E5%80%8D%E7%B2%BE%E5%BA%A6%3C%2FP%3E%3CP%3EfNum%20-%26gt%3B%20%E6%B5%AE%E5%8B%95%E5%B0%8F%E6%95%B0%E7%82%B9%E6%95%B0%3C%2FP%3E%3CBR%20%2F%3E%3CP%3ECASE%201%3A%3CBR%20%2F%3E%20dNum%20%3D%20FLT_MAX%20*%202%3B%3CBR%20%2F%3E%20fNum%20%3D%20(float)dNum%3B%3CBR%20%2F%3E%20%E2%86%92%20%E4%BE%8B%E5%A4%96%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ECASE%202%3A%3CBR%20%2F%3E%20dNum%20%3D%20FLT_MIN%20%2F%202%3B%3CBR%20%2F%3E%20fNum%20%3D%20(float)dNum%3B%3CBR%20%2F%3E%20%E2%86%92%20%E4%BE%8B%E5%A4%96%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ECASE%203%3A%3CBR%20%2F%3E%20dNum%20%3D%20FLT_TRUE_MIN%20%2F%202%3B%3CBR%20%2F%3E%20fNum%20%3D%20(float)dNum%3B%3CBR%20%2F%3E%20%E2%86%92%20%E4%BE%8B%E5%A4%96%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ECASE%204%3A%3CBR%20%2F%3E%20fTmp%20%3D%201.e%2B30f%3B%3CBR%20%2F%3E%20fNum%20%3D%20fTmp%20*%20fTmp%3B%3CBR%20%2F%3E%20%E2%86%92%20%E4%BE%8B%E5%A4%96%E3%81%AF%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3ECASE%205%3A%3CBR%20%2F%3EfTmp%20%3D%201.e-20f%3B%3CBR%20%2F%3EfNum%20%3D%20fTmp%20*%20fTmp%3B%3CBR%20%2F%3E%E2%86%92%E4%BE%8B%E5%A4%96%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F!%3C%2FP%3E%3CP%3ECASE1%E3%81%A7%E4%B8%8A%E9%99%90%E3%82%92%E8%B6%85%E3%81%88%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AB%E4%BE%8B%E5%A4%96%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E3%81%AA%E3%81%9C%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3CBR%20%2F%3E%E3%81%BE%E3%81%9F%E3%80%81%E4%BE%8B%E5%A4%96%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%99%E3%82%8B%E6%AD%A3%E7%A2%BA%E3%81%AA%E6%9D%A1%E4%BB%B6%E3%82%92%E7%9F%A5%E3%82%8A%E3%81%9F%E3%81%84%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2248757%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Exception%20IVOR33%20in%20MPC5777C%20Floating-Point%20Operations%20and%20Exception%20Conditions.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2248757%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESPESFCR%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%20FINVE%2FFDBZE%2FFUNFE%2FFOVFE%20%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E3%81%97%E3%81%8B%E3%81%97%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81SPESFCR%20%3D%200x0020303B%20(FINXS%2FFG%2FFX%2FFINVE%2FFDBZE%2FFUNFE%2FFRMC(11))%20%E3%81%A8%E8%A1%A8%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3EFOVFE%E8%A8%AD%E5%AE%9A%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%97%E3%81%9F%E3%81%AE%E3%81%AB%E5%8F%8D%E6%98%A0%E3%81%95%E3%82%8C%E3%81%AA%E3%81%84%E3%81%AE%E3%81%AF%E4%B8%8D%E6%80%9D%E8%AD%B0%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2248239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Exception%20IVOR33%20in%20MPC5777C%20Floating-Point%20Operations%20and%20Exception%20Conditions.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2248239%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3ESPEFSCR%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22davidtosenovjan_0-1764062727726.png%22%20style%3D%22width%3A%20665px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22davidtosenovjan_0-1764062727726.png%22%20style%3D%22width%3A%20665px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22davidtosenovjan_0-1764062727726.png%22%20style%3D%22width%3A%20665px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22davidtosenovjan_0-1764062727726.png%22%20style%3D%22width%3A%20665px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367129i2C42864FE30752BB%2Fimage-dimensions%2F665x554%3Fv%3Dv2%22%20width%3D%22665%22%20height%3D%22554%22%20role%3D%22button%22%20title%3D%22davidtosenovjan_0-1764062727726.png%22%20alt%3D%22davidtosenovjan_0-1764062727726.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2249311%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Exception%20IVOR33%20in%20MPC5777C%20Floating-Point%20Operations%20and%20Exception%20Conditions.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2249311%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%90%8C%E3%81%98%E3%82%B3%E3%82%A2%E3%82%92%E6%8C%81%E3%81%A4%20MPC5674F%20(MPC5777C%20%E3%81%AF%E7%8F%BE%E5%9C%A8%E5%85%A5%E6%89%8B%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93)%20%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%80%81%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E5%86%85%E3%81%AE%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%82%92%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%82%A2%E3%82%BB%E3%83%B3%E3%83%96%E3%83%A9%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E4%BD%95%E3%82%89%E3%81%8B%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%8C%E3%81%82%E3%82%8B%E3%81%A8%E6%80%9D%E3%82%8F%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2255706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Exception%20IVOR33%20in%20MPC5777C%20Floating-Point%20Operations%20and%20Exception%20Conditions.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2255706%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%8A%E8%BF%94%E4%BA%8B%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3ESPESFCR%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E6%A7%8B%E6%88%90%E3%81%95%E3%82%8C%E3%80%81%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8B%3F%3C%2FP%3E%3CP%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%9F%E3%81%A8%E3%81%84%E3%81%86%E3%81%AE%E3%81%AF%E3%80%81%E5%85%B7%E4%BD%93%E7%9A%84%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%86%E3%81%84%E3%81%86%E6%84%8F%E5%91%B3%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3ESPESFCR%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%E3%81%AEFOVFE%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E4%B8%8A%E8%A8%98%E3%81%AE%E3%83%86%E3%82%B9%E3%83%88CASE1%E3%81%A7%E4%BE%8B%E5%A4%96%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E
