Erasing and reprogramming the board
907 次查看
Ahmed_Abd_El-Hafez
Hello NXP team,
I am using board MPC5744P and uploading the .mot file to it using the RAppID bootloader but suddenly, it can't erase and programmed using the RAppID bootloader as I do usually. What may be the reason and what is the solution of this. Is there an option to reset the factory programming of the board?
Thank you in advance
Best Regards
Ahmed
0 回复数
