Enet_rmii_udp example code not working more than 14 bytes
rakkumuthur
I am using MPC5748G enet_rmii_udp example code using s32 design studio IDE to send data from evaluation board to the PC. I am able to send up to 14bytes not more than. But I am able to see the UDP packet  in wireshark but the application (netcat in linux [Example: nc -u -l port]) is not receiving the packet.
Any help provided is appreciated.
