Hello everyone,
Although I cannot see any detail about how to check EQADC calibration results on reference manuel, there is an error function on the an example of EQADC. I attached the function photo below.
What is the reason of 0xF between paranthesis of the if statement?
Also, I would like to learn which document the calibration result check has been mentioned in.
Sincerely.
Solved! Go to Solution.
This checks whether converted references are similar to ideal value. Values are converted with calibration, 0xF fits to TUE value (some devices may defines less).
