ECSM's software watchdog?
1,350 次查看
huafang
I want to use MPC5554 chip ECSM module software watchdog, related documents?
1,255 次查看
davidtosenovjan
ECSM's software watchdog timer is not recommended to use on MPC5554 device.
For core watchdog you may see following appnote:
https://www.nxp.com/docs/en/application-note/AN2817.pdf
If you want only disable core watchdog, you may use following function:
asm
    mfhid0  r11               /* Move from spr HID0 to r11 (copies HID0) */
    li      r12, 0xBFFF       /* Load immed. data of ~0x4000 to r12 */
    oris    r12, r12, 0xFFFF
    and     r11, r12, r11     /* OR r12 (~0x00004000) with r11 (HID0 value) */
    mthid0  r11               /* Move result to HID0 */
    lis     r12, 0x00
    mtspr   tcr, r12          /* clear SPR TCR register */
