Hi.all
in 5744p datasheet:
PWMA/PWMB has no Capture founction ?
but
SUIL.IMCR[112] =1; FlexPWM_1 Channel A input
who can tell me,Channel A/B has capture functions or not?
Thank you!
Clipping
The PWMA[n] and PWMB[n] are just an outputs. The input capture feature is not implemented on these pins. Also you do not have control registers for capture feature on PWMA[n] and PWMB[n]. Only the PWM[X] can be used for this feature and capture control registers are available for PWM[X] pin.
BR, Petr
Where can I find examples?
