Disable VLE assembly
jordancyre
I'm trying to find a way to disable VLE instructions when compiling my program.  I found this thread and tried the solution but it didn't work.  S32DS: How to force non-vle build for the entire p... - NXP Community
My command line pattern  looks like this: `${COMMAND} ${FLAGS}-mno-vle ${OUTPUT_FLAG} ${OUTPUT_PREFIX}${OUTPUT} ${INPUTS}`
I've attached what my assembly looks like.
I'm really new at all of this so i ask you patience if I don't understand right away.  End goal is to use only non-VLE instructions.
stanish
jordancyre
Turns out my devkit likely doesn't support non-VLE instructions.
I'm using the MPC5748G and the most recent version of S32DS.
Here's a link to the reply about VLE on the MPC5748G:  I don'nt know how to enter debugging mode on MPC57... - NXP Community
davidtosenovjan
Sure, you haven't specify the used MCU.
The only MPC57xx devices supporting BookE instruction set is MPC5777C or MPC5775B/E. All others are VLE only.
davidtosenovjan
I have tried this and it works to me.
${COMMAND} ${FLAGS} -c -mno-vle ${OUTPUT_FLAG} ${OUTPUT_PREFIX}${OUTPUT} ${INPUTS}
In the DS, you may see example code:
davidtosenovjan
Hi, could you specify version of S32 Design Studio?
