Difference in speed between sram datasheet and c language coding
jjangyja
void test_func()
 unsigned int i = 0;
   for(i = 0;i < 52560;i++)
    test_buffer_out[i] = test_buffer_in[i];
 i = 0;
byte : 52 KByte
for loop time : 5.576 ms !!!!!
and....
SRAM DataSheet
* Features
 - Fast-clock-to-output times
   8.0 ns (100-Mhz Version)
- 16bit Databus
8.0 ns (2 Byte Read/Write Speed)
8.0ns   ===>  5.57 ms Calculate the capacity to process in 1.39 MB.
for loop : DataSheet
56 KB : 1.39 MB
Why is this big difference in capacity (byte)?
