Detailed Pin Description for MPC5746C
3,951 次查看
mandarpande
For MPC5746C, is there any document providing pin description for each pin functionality. We are refering IO_Signal_Description_and_Input_multiplexing_tables.xls, which is attached in the MPC5746C reference manual, for the Pin Diagram but could not find the detailed description for each pin.
It would be helpful if there is any document for the pin function description. If any such document exists, please attach it in reply.
Mandar
PS: I have attached the document I am referring here.
标签 (1)
标记 (2)
1 回复
3,367 次查看
davidtosenovjan
Detailed signal description you may find in reference manual at the beginning of particular module description.
For instance like this screenshot taken from I2C section:
