Dcache as RAM to increase RAM size in MPC5777C
已解决
跳至解决方案
2,167 次查看
Indra
Hi everyone, I want to  use dcache as ram to increase the available ram size. I referred a cookbook (AN2865 Qorivva Simple Cookbook) in the section Cache as RAM it says, to use cache as ram the cache should be invalidated and enabled in copyback mode. All I want is to increase my ram size my using dcache 16kb memory as ram is that possible is possible how?
BR,
Indra
1 解答
2,134 次查看
davidtosenovjan
1 回复
2,135 次查看
davidtosenovjan
