DCF Records BOOTCFG1 Configuration
KarlS
Hi everyone,
I'm curious if there is a way to enable/ disable the external BOOTCFG1 pin within the DCF Records. This is the same pin that can force the processor to enter serial boot mode when the value for BOOTCFG1 is set from 00 (internal boot) to 01 (serial boot).
Sincerely,
Karl
petervlna
No, there is no such possibility to configure BOOTCFG via DCF record.
Peter
petervlna
For what microcontroller is this question?
All available DCF configurations are always described in reference manual.
Peter
KarlS
Hi Peter,
This would be for the MPC5777C microcontroller.
Thank you,
Karl
petervlna
Peter
