Complementary PWM signal
1,865 次查看
shitalshitole
How to generate complementary PWM signal using given PWMMAC and PWMF   NXP function set?Please explain with any example code
标签 (1)
2 回复数
1,772 次查看
petervlna
Could you be more specific?
Which device do you use?
Which module do you refer?
Peter
1,772 次查看
shitalshitole
I am using  MPC5777c MCU and ETPU A module used to generate PWM signal.I am trying to produce complementary PWM signal using PWMMAC and PWMF NXP function set but I only getting master channel PWM signal not any signal at Phase A channel.
