Complementary PWM signal
1,837件の閲覧回数
shitalshitole
How to generate complementary PWM signal using given PWMMAC and PWMF   NXP function set?Please explain with any example code
2 返答(返信)
1,744件の閲覧回数
petervlna
Could you be more specific?
Which device do you use?
Which module do you refer?
Peter
1,744件の閲覧回数
shitalshitole
I am using  MPC5777c MCU and ETPU A module used to generate PWM signal.I am trying to produce complementary PWM signal using PWMMAC and PWMF NXP function set but I only getting master channel PWM signal not any signal at Phase A channel.
