Communication Ethernet + CAN
3,489 次查看
Buo_Nto
Good evening everyone.
I am using an MPC5748G Devkit board; my project foresees an incoming Ethernet communication with TCP protocol and a CAN outgoing communication with a control unit. I tried to merge the two example projects LWIP and CAN but I have an error, how can I proceed? Is there a guide I can follow?
Thanks a lot in advance
3,451 次查看
lukaszadrapa
there's a nice presentation and examples for S32K148:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiYiNrDysP6A...
I will send you the examples separately.
Lukas
5 回复数
3,462 次查看
Buo_Nto
Thank you so much lukas, for your answer, my plans have changed and at the moment the idea is to have a communication between the mpc5748G and another board. Can you confirm that for the TPC / IP protocol I have to start from the LWIP example project of s32 and create my sockets through the netconn api?
Thanks in advance.
3,467 次查看
lukaszadrapa
Hi Antonio,
no, there's no guide for such particular case. We provide only set of SDK examples and user manual:
c:\NXP\S32DS_Power_v2.1\S32DS\software\S32_SDK_S32PA_RTM_3.0.3\doc\S32SDK_MPC5748G_UserManual.pdf
Also notice that we provide only very limited support for lwip because it is open source. We can provide the support only if it is related to integration to SDK.
https://lwip.fandom.com/wiki/Further_lwIP_support
Lukas
3,461 次查看
Buo_Nto
Thank you so much Lukas for your answer. My plans have changed and at the moment the idea is to have a communication between the mpc5748G and another board. Can you confirm that for the TPC / IP protocol I have to start from the LWIP example project of s32 and create my sockets through the netconn api?
Thanks in advance.
3,452 次查看
lukaszadrapa
Lukas
3,444 次查看
Buo_Nto
Thank you so much for your support Lukas.
Antonio.
