Code compression MPC556
juninholiveira90
Hi there. I'm working on a legacy MPC556 microcontroller where I don't have an option to change it. I need any code compressor. Reading MPC555UM, I could find the following at 4.3.1: "Compression is done off line by a special compressor tool, using a fixed vocabulary instruction based algorithm, optmized for the PowerPC instruction set."
I've searched for some compiler or even other tool to compress my C code but I've no idea which one I must use. I saw somebody mentioning about Squeezard compressor but I couldn`t find it to download or even buy it. Is there something I can do to compress my C code ? It can be any tool (compiler with a compression option or compressor software) even in case I need to buy it!
My last option will be to develop by my own but I don't know how tough is that.
Alexshamko
Hi, colleague! Have you managed to find any information about the code compression mechanism? Please contact with me [email protected]
lukaszadrapa
Hi @juninholiveira90
I'm sorry but the tools and documentation for code compression are not available anymore.
Also MPC555/556 are already in End Of Life status, the device is no longer manufactured, so it's not supported anymore.
Lukas
%3CLINGO-SUB%20id%3D%22lingo-sub-1890621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ECode%20compression%20MPC556%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1890621%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20there.%20I'm%20working%20on%20a%20legacy%20MPC556%20microcontroller%20where%20I%20don't%20have%20an%20option%20to%20change%20it.%20I%20need%20any%20code%20compressor.%20Reading%20MPC555UM%2C%20I%20could%20find%20the%20following%20at%204.3.1%3A%26nbsp%3B%3CEM%3E%3CSTRONG%3E%22Compression%20is%20done%20off%20line%20by%20a%20special%20compressor%20tool%2C%20using%20a%20fixed%20vocabulary%20instruction%20based%20algorithm%2C%20optmized%20for%20the%20PowerPC%20instruction%20set.%22%3C%2FSTRONG%3E%3C%2FEM%3E%3C%2FP%3E%3CP%3EI've%20searched%20for%20some%20compiler%20or%20even%20other%20tool%20to%20compress%20my%20C%20code%20but%20I've%20no%20idea%20which%20one%20I%20must%20use.%20I%20saw%20somebody%20mentioning%20about%20Squeezard%20compressor%20but%20I%20couldn%60t%20find%20it%20to%20download%20or%20even%20buy%20it.%20Is%20there%20something%20I%20can%20do%20to%20compress%20my%20C%20code%20%3F%20It%20can%20be%20any%20tool%20(compiler%20with%20a%20compression%20option%20or%20compressor%20software)%20even%20in%20case%20I%20need%20to%20buy%20it!%3C%2FP%3E%3CP%3EMy%20last%20option%20will%20be%20to%20develop%20by%20my%20own%20but%20I%20don't%20know%20how%20tough%20is%20that.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2423771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Code%20compression%20MPC556%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2423771%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EHi%2C%20colleague!%20Have%20you%20managed%20to%20find%20any%20information%20about%20the%20code%20compression%20mechanism%3F%20Please%20contact%20with%20me%20shamko.alex%40gmail.com%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1891074%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Code%20compression%20MPC556%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1891074%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F214067%22%20target%3D%22_blank%22%3E%40juninholiveira90%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI'm%20sorry%20but%20the%20tools%20and%20documentation%20for%20code%20compression%20are%20not%20available%20anymore.%3C%2FP%3E%0A%3CP%3EAlso%20MPC555%2F556%20are%20already%20in%20End%20Of%20Life%20status%2C%20the%20device%20is%20no%20longer%20manufactured%2C%20so%20it's%20not%20supported%20anymore.%3C%2FP%3E%0A%3CP%3ERegards%2C%3C%2FP%3E%0A%3CP%3ELukas%3C%2FP%3E%3C%2FLINGO-BODY%3E
